Turk Posted May 9, 2014 Posted May 9, 2014 Hi i just wanted to know if this does actually work because i have read alot of stuff and im not sure. Ive just got some levin twinpots and the caliper carriers. From what ive read you can run 276mm discs from a levin with a 3mm spacer behind. If this is true ill like my setup to be like this. Also would it fit under 15s.If this does not work is the astra discs a straight fit with no spacers. Ive heard i just need to shave 1mm from the middle to make them fit. Pls correct me on anything i might have said wrong. Quote
richardc9052 Posted May 9, 2014 Posted May 9, 2014 Levin twin pots, corolla single pot carriers, 1.8vvti mr2/mrs disks.. No spacers and no machining of disks. Just a slight filing of the actual caliper which is needed for any of the other combinations as well ;) Quote
Turk Posted May 9, 2014 Author Posted May 9, 2014 Levin twin pots, corolla single pot carriers, 1.8vvti mr2/mrs disks.. No spacers and no machining of disks. Just a slight filing of the actual caliper which is needed for any of the other combinations as well ;)Whats the exact disc size. Ive looked into them discs and they are 20mm thick while everyone else use 25mm thick discs. So i was confused. Also where do i need to file down on the caliper? By the way are you running this setup? Quote
