Happyb Posted May 14, 2014 Posted May 14, 2014 Need a distributer for a 5efhe engine with acis and an internal coil!
5e colin Posted May 14, 2014 Posted May 14, 2014 internal coil ??? you can use the 4efe dizzy then if its external coil you can use 4efte coil i have a external 5efhe dizzy on the 4efte
Happyb Posted May 14, 2014 Author Posted May 14, 2014 Yea it's internal coil and the 4efe and the 5efhe are different! They are different voltages!
5e colin Posted May 15, 2014 Posted May 15, 2014 i dont know how you want internal coil ??????????? 5efhe is either external coil like 4efte or dis no dizzy attal just a camshaft sensor on the intake shaft what voltage are u on about ?? what the internal coil produces ??? that makes no diference
