renfrewshiremod_craig Posted May 29, 2014 Posted May 29, 2014 Year: 1998Model: glanzaTax: end of octoberMOT: 12 monthsMileage: 92000Description:Hi i am selling my much loved Toyota Starlet Glanza which i have owned for nearly 3 years now. Just feel it is time for a change to something a bit bigger. This car is really fun to drive but not for the faint hearted it was dyno'd at 240bhp with print out. It is always run on Shell V-power and warmed up and cooled down. it has regular oil changes every 3K using 5w30 castrol oil (changed 1k ago). It has 12 months mot and taxed till end of October. I have loads of reciepts for this car including original import docs. Car was imported 21/03/08. Timing belt and water pump was changed 2012 at 78K (126km). Reciently fitted a new stage 4 competition paddle clutch and flywheel.When the clutch was fitted the gearbox was also sent away and given a once over to make sure everything was ok. When i bought the car it was sent away for a full respray in original 040 Toyota Super White to give it the fresh look it deserves. For a 16 year old car it looks brilliant there are a couple of very minor faults but thats me being picky but trying to be as honest as possible. When i bought the car i was made aware that it was the second engine that had been put in the car as the owner before blew the first one up. I was told it was a Forged engine but have no paperwork to prove this. The engine runs very smooth doesn't idle rough or smoke on start or anything like that. The turbo pulls very well doesn't smoke on boost. Very rarely if the car hasnt been driven on boost when you hit boost it will have a small bit of smoke for only a second and is then clear again usual with turbo's and decat cars. Also when i bought the car The owner before had an oil pressure and oil temprature gauge mounted on the dash but not wired in so i removed these so there are a couple of small holes but the new owner could easily fit new gauges.Spec:Interior:Recaro front seats with LUKE harnesses ( the seats could be doin with low rails but thats me just being fussy again)I have removed the rear seats and painted the inside ( there is a couple of really small paint chips n marks)Custom made half roll cage full bolt in for easy removal ( couple of paint chips on it)Pioneer Flipout dvd/cd /mp3 playerOmex launch control ( never used)Quick release Steering wheel (horn and self cancel indicators all work)Carbon gauge pod with Boost/Voltage/Water temp gauges all in redGizzmo electronic boost controllerPlazma dialsSparco Gear knobALARM/ECU:Clifford G5 alarm profesionally installed has remote start function great on cold mornings and to warm up engine.Built in Turbo Timer in alarmDaztec piggyback ECU. Removes feul cut and speed limiter it has never been remaped but runs perfect.EXTERIOR:Original 98' spec front bumper with front lip moulded inReverse bonnet scoop ( i have original scoop to)Bonnet raisersOEM wind deflectors ( drivers side has a small piece broken)Ducktail rear spoilerJDM rear lights ( also have originals)Tein monoflex coilovers ( passenger rear has a slight rattle from top mount)Volk Rays TE37 rep wheels ( couple have centre mark flaking and very small scuffs)WEPR mild steel manifold heatwrappedIHI VF24 rollerbearing turbo (wastegate welded shut)Tial external wastegate to screamer pipe ( sounds awwsome)DecatBLITZ Nur-spec exhaust (flexi has been caught on a couple of speed bumps but not blowing or anything to worry about)Front mount intercooler with custom pipes for big turbo set-upAluminium twin core civic radiatorLow temprature thermostatSARD feul pressure regulatorWalbro 255 uprated feul pump Stage 4 AC Competition race clutch and flywheel ( speedo converter fitted and clocks adjusted to miles)OEM LSD gearboxRelocated airfilter to behind front grillPolybushed Engine and Gearbox mountsReciently new alternator and power steering belts fittedWhen i bought the car it was fully undersealed and i have done once a year since. As i am a mechanic i have done alot of the work myself and spared no cash on buying the best parts possible for this car. it has been my pride and joy but time to move on. im sure i have missed loads of extra's but if i can remember i will edit the advert later. Only other things i can think of is there is a very small chip on the front windscreen at the top which i got checked when i bought the car but was told it had been filled and it hasnt got any bigger since. also the passenger wind mirror doesnt fold in the motor just seems to spin inside so i disconected it.Like i said before it has a couple of small faults nothing to do with the running or driving of the car but im trying to be as honist as possible. I have advertised this car elsewhere so reserve the right to remove it at any time or if a deal is met before the auction finishes. any questions please message me and i will get back to you as soon as possible.Craig Price: £4500 ono looking for quick sale to fund my new project Pictures:Contact Details: text me on 07887722409 or email me on renfrewshiremodified_craig@hotmail.co.uk
renfrewshiremod_craig Posted June 21, 2014 Author Posted June 21, 2014 Right guys £4000 takes this or i will strip it would he ashame to strip such a good quick clean shell Roll cage is sold tho so not included
*GlanzaTurboV* Posted July 7, 2014 Posted July 7, 2014 Could only offer a swap for my 2005 impreza, looks perfect for me
richdog Posted July 7, 2014 Posted July 7, 2014 Contact user name robnza he is after something like this.
YidoDylan Posted July 11, 2014 Posted July 11, 2014 I'd seriously consider buying this, shame you're in Scotland!
jimmymac101 Posted July 11, 2014 Posted July 11, 2014 You have to travel for the best cars these days !! james
Drue1 Posted July 11, 2014 Posted July 11, 2014 How far are you from kames race track as I'm sprinting my motor there next sat
