_shaun_ Posted June 1, 2014 Posted June 1, 2014 well cars had the issue since i got it i figured it was the map on the emu but its been remapped and still causing issues mapper thinks its an immobilizer issue but just strange it firsts first time from cold.basically if i get the car up to temp and turn it off leave it to cool slightly and try start it again its a total lottery if it will start might go first time might take 10 attempts but its cranking and getting fuel spark and air? any ideas? its a toad 606i alarm so think ill try disconnect that and see if it helps any cheers shaun Quote
_shaun_ Posted June 1, 2014 Author Posted June 1, 2014 hmm gonna sound stupid but will changing my tps alter the map any? Quote
DevonGT Posted June 1, 2014 Posted June 1, 2014 It's something to do with the emu and values in boxes and just changing them. Quote
DevonGT Posted June 1, 2014 Posted June 1, 2014 As it's only something I've heard about and I'm by no means an expert, I've done some searching and this might help. http://www.toyotagtturbo.com/forums/showthread.php?72782-E-manage-ultimate-warm-start-issue. http://www.toyotagtturbo.com/forums/showthread.php?73480-warm-start-problem-now-mapped&highlight=warm+start+issue Quote
_shaun_ Posted June 1, 2014 Author Posted June 1, 2014 your a champ! cheers ill try catch chris and speak to him then check with ma mapper make sure hes alright with me playing with map Quote
mi16chris Posted June 1, 2014 Posted June 1, 2014 Email me the map to mi16205@hotmail.com the tps needs to show a low value or the green light will blink and won't fire any fuel as it's trying to clear the plugs Quote
_shaun_ Posted June 1, 2014 Author Posted June 1, 2014 with out trying to be a pain anyway i can do it with out e-mail? dug out my old laptop to plug in but it wont connect online for some reason. Quote
mi16chris Posted June 1, 2014 Posted June 1, 2014 Have u got a way to download and ajust the emu data Quote
_shaun_ Posted June 1, 2014 Author Posted June 1, 2014 The laptops got the emanate software on it so I can change things via that Quote
mi16chris Posted June 2, 2014 Posted June 2, 2014 The laptops got the emanate software on it so I can change things via that go online and go to the tps set up , change the min and max value untill your tps is setting close to 0% that will be it sorted Quote
_shaun_ Posted June 2, 2014 Author Posted June 2, 2014 Ahh sweet so want it to be sitting at 0% at idle?. Outta curiosity what's the reason why its currently not firing? But will either these settings changed Quote
mi16chris Posted June 2, 2014 Posted June 2, 2014 Ahh sweet so want it to be sitting at 0% at idle?. Outta curiosity what's the reason why its currently not firing? But will either these settings changed when the tps is too high it will think your trying to clear the spark plugs and dose not fire any fuel in Quote
_shaun_ Posted June 3, 2014 Author Posted June 3, 2014 Ahh so should I change the tps values when its warm? Or cold work fine? Quote
mi16chris Posted June 3, 2014 Posted June 3, 2014 Ahh so should I change the tps values when its warm? Or cold work fine?wont make any odds Quote
