I just started up the engine it idled on 2k for a couple minutes and then it started hunting for idle.
if i try to give little revs its splutters.
ive got a fcd fitted but im not using it; can that cause the engine to idle rough?
If i set the fcd to 0 will it disable it?
What can cause the idle to hunt?
Thanks
could be a couple of things..
Is the vac line to map sensor split or loose?
How is your idle control valve (may need cleaning/replacing)
Do a diagnostic test otherwise you could spend hours searching
Ill have a look at the map sensor vac line and see if i can see a split pipe.
When i remove the plug for tps when the Engine is running and no difference.
Ive had a look and i fink ive found the problem.
When i remove the plug for tps while the engine is running and it starts to idle very high. At 3500rpm.
and when the plug is connected it starts hunting for idle again between 1000rpm to 1500.
Is the tps sensor faulty or does it need a clean and needs to be setup correctly.
.ive got a 1.9mm head gasket can this cause anything. ?
Thanks
