How the hell do you get the window winder off the door card of an n/a starlet??!! its an EP91 and ive popped all the little popers off it, unscrewd the door handle bolts, and now the only thing holding it seems to be the windscreen wiper, and i cant get it off or see how it will come off!! been messin with it for about 20 mins now and realy dont want to rip the bastard off!! please reply asap as im still out in the garage and will be till late tonight!!!
any help lads w ud be great... taaa
take the trim panel off your doors, find a really long flat head screwdriver is the best thing to use to get the pin out of the window winder. you have to push the trim in slightly and you will see the window winder pin, just push it and it will pop out. its like a U shape.
there is a butterfly clip behind the winder. use a flat head screw driver and you have to push the clip off. if you pull the winder back you can c it
