nomzey10 Posted June 14, 2014 Posted June 14, 2014 my lambda sensor is making my glanza run very rich. im looking to replace it but i dont know if i can use a universal sensor or do i need a specific sensor for glanza turbos.ive found this universal lambda sensor on ebay, item number is 310846072993 or do i have to buy this one http://www.id-workz.co.uk/index.php?main_page=product_info&cPath=3_1118_8_102&products_id=5204&zenid=5523b99bd377e086b47c4c130ce98674 Quote
richardc9052 Posted June 14, 2014 Posted June 14, 2014 Are you sure the wire isnt cut/damaged any where? They usually cause a lean mixture when faulty which is then fixed by unplugging the lambda. Are you sure its the lambda? have you tried doing a diagnostics check? Could be plenty or other things as some sensors cause max fuel like the map sensor being unplugged or wire being damaged Quote
nomzey10 Posted June 14, 2014 Author Posted June 14, 2014 yh m8t its deffo the lambda sensor got it diagnosed. do i have to get a specific sensor for glanza turbos? Quote
