GT_Neil Posted December 17, 2007 Posted December 17, 2007 My GT sqeeks when i turn the wheel when parking, or generally moving slowly. also there is a clunking or knocking comming from the left wheel area, this is most noticable when reversing?? anyone got any ideas? only noticeable at slow speeds.. Quote
Bourkey Posted December 17, 2007 Posted December 17, 2007 Mine did this the other day. My dad says the wheels bearing just needs re greasing. Anyone got anything else it could be? Quote
GT_Neil Posted December 17, 2007 Author Posted December 17, 2007 ah i do know that my front left wheel bearing was just replaced before i brought the car. ...that could explain the squeak ... but not the knocking? Quote
Glanza Al Posted December 19, 2007 Posted December 19, 2007 Have you got aftermarket coilys on it Neil?Alex. Quote
GT_Neil Posted December 19, 2007 Author Posted December 19, 2007 no it came with a kyb suspension kit, which im not to sure about really. .. . Quote
Glanza_Ragger Posted December 30, 2007 Posted December 30, 2007 no it came with a kyb suspension kit, which im not to sure about really. .. .Knocking from a wheel could be a number of things, try the simple things first like checking the torque on the hubnut, checking all the bolts are tight to the damper etc.Also when the wheels in the air give it a shake to see if theres any play in the wheel bearing.It could feel fine, but wheel bearings tend to make a knocking which lead into a worrying grinding noise, thats basically when its about to collapse Quote
