ash p Posted July 19, 2014 Posted July 19, 2014 am after the a seal I have a oil sandwich plate which the sensors for my gauges go into am after the oil seal or seals as it maybe two am not sure which go on the other side of the sandwich plate attaching it to the block the sandwich plate did not come with one where can I get one? Quote
akyakapotter Posted July 19, 2014 Posted July 19, 2014 you on about the rubber o-ring ? use one from an old oil filter Quote
ash p Posted July 19, 2014 Author Posted July 19, 2014 Yes mate andvi was thinking that will it fit as one side of the sandwich plate is flat and is sealed with the filter o ring the other side does have grooves in it it might fit actually hopefully it doesn't leak and starv my engine of oil lol Quote
akyakapotter Posted July 19, 2014 Posted July 19, 2014 Flat side is where you oil filter goes side with groovs goes on the housing and the oring seals it there mine hasn't leaked yet Quote
ash p Posted July 19, 2014 Author Posted July 19, 2014 Ok I will try it and have a see cheers mate Quote
