FrozenJakalope Posted July 22, 2014 Posted July 22, 2014 Hey guys, The bite on my clutch is really high, to the point where I can change gear smoothly by depressing the pedal about 5mm. There's also a lag between revs increasing and speed increasing, ie I floor the throttle and engine noise goes way up but speed catches up quite gradually. Oddly, though, the car will stall out perfectly well if I let the clutch out when still. Wouldn't clutch wear cause some slipping before stalling? I've never had any dealings with hydraulic clutches before, could it be a problem with the fluid? Or do I need a whole new clutch assembly? Cheers,Josh Quote
FrozenJakalope Posted July 23, 2014 Author Posted July 23, 2014 Pressure plate was worn all to hell, it went this morning. New clutch it is. Quote
