Just did a diagnostic on my Glanza and getting fault code 25 back which is " Air-fuel ratio lean malfunction" !
I'm slightly in the dark as the trouble area seems to be pretty large, injector, injector circuit, oxygen sensor circuit, oxygen sensor, ecu, fuel line pressure, map sensor circuit, map sensor, air intake and the ignition circuit.
The car is running E-manage blue and was fitted a month or so ago by TD
I really don't no where to start to be fair , i don't want to or think i should start playing with fuel pressure or anything like that
My only option looks like a trip to TD which is about 3 hours for me from Stevenage
Any help or advice
Edited by GlanzaJ
