TD04HYBRID Posted July 27, 2014 Posted July 27, 2014 Item For Sale:HKS EVC 6 Boost ControllerItem Condition & Description:Used- Full working condition Comes with everything needed. FeaturesHigh Boost Capability * 250kPa/36PSITarget Boost * User inputs target boost level, and the EVC automatically adjusts pressure to reach desired level.Offset Function * If boost exceeds or does not achieve user’s target, boost pressure can be offset to reach desired level.Map Correction Mode * Boost pressure can be fine tuned for: Throttle Position, RPM, Vehicle Speed, Throttle Position + RPM, or Throttle Position + Vehicle Speed.Dual Boost Mode Settings * Separate A and B boost levels can be input independently from each other, and selected depending on driving conditions.Scramble Boost Function * When the scramble boost trigger is depressed a preset boost increase will occur for a predetermined time (0-60seconds). * External Scramble Boost Trigger compatible.Metric or SAE selectable monitoring * Users can choose during initial setup metric (kPa) or SAE (PSI) boost pressure measurement for monitoring.Warning Function with Boost Drop Feature * A user preset warning level can be set where visual and audible alerts occur if the warning level is reached. Boost pressure can be preset to drop to a user defined level if pressure reaches warning level.Analog and Digital Boost Monitoring * Boost pressure can be displayed in both an analog bar graph format and a digital numerical value.Additional Digital Monitoring * Along with Boost Pressure two additional vehicle vitals can be monitored: Throttle Position, Engine RPM or Vehicle Speed.Selectable Analog Monitoring * The digital bar graph can be set to monitor: Boost Pressure, Throttle Position, Engine RPM or Vehicle Speed.After Image Function * Users can set the EVC to display the highest boost pressure reached for 3-seconds after the throttle has been released.Peak Hold * The EVC will store to memory and keep displayed the maximum boost achieved.Data Lock * To prevent accidental data changes from occurring, the EVC can be locked with a user defined four digit code.Positive LCD display with LED Lighting * Black foreground with white background and LED lighting provides excellent visibility during both daytime and nighttime use.Dimmer Function * Brightness of display can be adjusted for user comfort.Rear Mounted Wiring harness * For a clean and simple installation the wiring harness connects to the back of the EVC unit.Price:£220 + Delivery & Paypal Fees - Brand new these are £550Pictures:Payment & Shipping Details: Collection Or Delivery at buyers cost - will only deliver to UK or Ireland
Brad93 Posted July 30, 2014 Posted July 30, 2014 Great seller, don't hesitate to buy. I bought the Emanage with no problems at all, really nice guy.
TD04HYBRID Posted July 30, 2014 Author Posted July 30, 2014 Great seller, don't hesitate to buy. I bought the Emanage with no problems at all, really nice guy. Cheers Pal Nice To Meet You
Zeldoz Posted July 31, 2014 Posted July 31, 2014 Does this include everything needed for fitment? Might buy this for my 200sx
TD04HYBRID Posted July 31, 2014 Author Posted July 31, 2014 It's does mate.... Everything that was wired into my car
Zeldoz Posted July 31, 2014 Posted July 31, 2014 Is this the color model?Looks like the 5? 6 is colour
Zeldoz Posted July 31, 2014 Posted July 31, 2014 Also, does it read in bar? Or, just PSI? What's the units condition like? Any scatches/marks etc?
TD04HYBRID Posted July 31, 2014 Author Posted July 31, 2014 Hi Mate, Its not colour but thats the early model of the 6 or might be the 5 i have looked it up on the internet. Its reads in both bar and psi depending on what you set it to. also has 2 setting one for external and one for internal wastegate. Condition is good on the visual side. On the back it has some seal on it where i mounted it into my center console but could be removed. Fully working my friend and they are still £550 new http://www.driftworks.com/hks-evc-vi-electronic-boost-controller.html Brilliant controller fella
Zeldoz Posted July 31, 2014 Posted July 31, 2014 Is this EVERYTHING that it originally came with? So i can fit this right away?
TD04HYBRID Posted July 31, 2014 Author Posted July 31, 2014 It came with the car when I brought it so I've got everything that it came with!
akyakapotter Posted July 31, 2014 Posted July 31, 2014 Yep looks like every thing is there I have the newest modle amazing bit of kit.
TD04HYBRID Posted July 31, 2014 Author Posted July 31, 2014 Yep looks like every thing is there I have the newest modle amazing bit of kit.Thanks for confirming pal
TD04HYBRID Posted August 1, 2014 Author Posted August 1, 2014 Bump Still For Sale People... Great Bit Of Kit
TD04HYBRID Posted August 4, 2014 Author Posted August 4, 2014 These are still £600 brand new! great bit of kit got so much to it
