Keiranstar168 Posted July 31, 2014 Posted July 31, 2014 I know this has been cover hundreds of times on here but it hasn't helped aha, I have a corolla tubular intake mani and what I want to know is how easy it is to fit, what adjustments to throttle cables and tb is needed, is it hard and how long will it take/ is there anything I should look out for or be careful with. Quote
onnaj1000 Posted January 3, 2015 Posted January 3, 2015 Hi, I'd like to know the same. I tried to mount it today but without luck :-(. The stock stays won't fit and there was no room to put my earth cable to. The throttle cable won't fit 1:1 but i think with a bit of bending i can make that work without a problem. I also think some vacuum hoses will not fit directly. Thanks folks! Quote
FMuscle Posted January 3, 2015 Posted January 3, 2015 You'll have to extend the brake booster and Map sensor lines. As for the throttle cable, I cut a slot in 2 washers and put them on each side of the bracket. Works good. for the earth, I'm still looking, I routed it to the fuel rail as it was the only reachable bolt, but I'm not sure if the contact is good enough yet.I didn't put the stays on, also I have a spacer making it even more unreachable...TB is bolt on though. As for something to look for, check if you have a coolant hole in the head on the dizzy side under the stock inlet, you might have to block it one way or another. Quote
