HI chaps
My clutch went Thursday :( managed to get a new one ordered and fitted by Friday night. All seems to be perfect real smooth but when i boot it and shift at high revs there is a small vibration goes through the clutch peddle when it press it but at low revs its fine nice and smooth? any ideas? didn't do this with the old clutch in only since I put the new clutch in?
Thanks
AShley
Could be a couple if things. Was the flywheel rubbed down with emery cloth or skimmed befor fitting new clutch? A the other is if the gearbox didn't go in very well and bent the friction plate a tad.
Chances are it's will be down to the first thing. I suspect it will bed in and go away over time.
thanks for the quick reply.
the flywheel wasn't rubbed down or anything just give it a little clean in the middle to get rid of bits of burnt clutch 8) .
Im hoping it will just fade away when i use it more to :)
Cheers for the help
