As titled ive been offered the front seat's from a corolla gti 92 for a good price, i'm just wondering what I'd need to do to get them to fit? If anyone has used these seats in a glanza maybe could give me some info!
Drill out the spot welds on the feet. Rotate and bend the rear left (driver seat) twist the front too slightly and enlarge the holes. Camt remember the rear rhs. Wasnt too bad but we did weld them back in place and reinforce the feet as we cut grooves in them to help bend them.
They sit quite far forward so if you're lanky youd be better off with different seats (im 5'9ish and was just right) Also when you slide them forward they catch the carpet on the exhaust tunnel.
I've still got one seat here i can get pictures of the feet if you want as they are mega comfy seats.
Right this is for the drivers seat. Obvs passengers would be opposite and excuse the mess its been an open shed 3 or 4 years.
Rear left.
Drill out spot weld spin bracket 90degress
Bend bracket so hole is vertical then reinforce once happy with position.
Rear right was untouched. Just with the bolt hole stretched
Front right is the same.
Front left needs to be rotated inwards slightly.
I think theres some locating pegs that need removing but thats about it.
