mattglanza79 Posted August 16, 2014 Posted August 16, 2014 My car has started smoking badly. Smells and looks like burning oil. There is no oil in hot pipe and put pcv to catch can to eliminate that. Smokes on idle and boost Quote
Shane 08 Posted August 16, 2014 Posted August 16, 2014 sounds like what mine was like check compression bet the piston or rings are going mine was like that for few months then blew. is there pressure coming from the rocker breathers oil vapour ect Quote
mattglanza79 Posted August 17, 2014 Author Posted August 17, 2014 Getting results on compression. No1 next to oil cap 135psi No2 145 psi. No3 135psi. No4 148 psiAny ideas as other than smoke car runs fine. No oil in down pipe or hot pipe of turbo either so doesn't look like oil seals Anyone know what compression should be ? Quote
mattglanza79 Posted August 17, 2014 Author Posted August 17, 2014 And yes getting pressure through the rocker breather Quote
mikey4410 Posted August 17, 2014 Posted August 17, 2014 Ure engines knackered dude. Engine comp should be 160+ on each cylinder. A healthy engine is around 170-175 psi per cylinder Oil coming out of your breather is indication of melted piston/cracked pistonAlso are you doin comp check correctly? Quote
mattglanza79 Posted August 17, 2014 Author Posted August 17, 2014 Took all plugs out then checked each one mate. Also noticed she is stalling on me and rough idle occasionally too Quote
mattglanza79 Posted August 17, 2014 Author Posted August 17, 2014 No oil out breather mate. Doesn't smoke on idle really just when I rev it also getting water out exhaust. Temp ok no oil in water etc but could be head gasket poss. Quote
mattglanza79 Posted August 17, 2014 Author Posted August 17, 2014 Haven't driven it for three weeks. Put fuel in it then all this starts Quote
Shane 08 Posted August 17, 2014 Posted August 17, 2014 its exactly same as what mine was smokeing little miss on idle cuttin out now and then and eventualy it went lost all comp on no 2 bet its rings Quote
mattglanza79 Posted August 18, 2014 Author Posted August 18, 2014 Gonna try some stop smoke see if that helps it till I can get it diagnosed properly Quote
mattglanza79 Posted August 18, 2014 Author Posted August 18, 2014 Mike from TD top lad. Thanks for the advice and for extra things to look at. Top lad thanks again. Quote
mattglanza79 Posted August 18, 2014 Author Posted August 18, 2014 And now it went BANG !!!!!!!!! Quote
Shane 08 Posted August 20, 2014 Posted August 20, 2014 was it rings like I said? mine did the exact same thing . compression test it mine was number 2 cylinder 0 compression Quote
mattglanza79 Posted August 21, 2014 Author Posted August 21, 2014 Compression was good warm plugs out and throttle open had 170 psi. Had a tapping noise then all went load and rattles like fook. Gonna take sump off and have a look but by sounds of it it sounds bollocked big time. Smoking out breather and won't run at all on idle. Quote
