Is it easy taking a ct9 turbo off? Oil seals gone in the turbo so smoking loads, is it a 10 minute job?
Any help appreciated thanks
  • 2 weeks later...
Won't take more than 1 hour if everything comes off,disconnect oil feed/return and waterlines,disconnect your downpipe from the exhaust side and remove your manifold bolts,should be 6 of them
Did you remove the radiator mate?i managed to take my manifold off without having to do that,was a bit of a pain but I got it :)
