alrite looking at getting a new rad fan. There is a 10inch 80w and a 10inch 120w, is there a specific one that i should use on a glanza v or will ether work?? Also does anyone know if there would be any difference i.e would one spin faster than the other etc? thanks a lot
Pretty much as you thought. 120w will move more air per minute.
Chances are the 80w would be ok but might need to be on for longer. If you're not sure get the 120w.
At the end of the day its only on when you're stationary.
