richardc9052 Posted September 1, 2014 Posted September 1, 2014 Have you got fuel in it? Seriously though, try checking the float on your pump to see if it's seized. If not, trace the signal wire back to the dash, there could be a break somewhere Quote
Azz Posted September 1, 2014 Author Posted September 1, 2014 Have you got fuel in it? Seriously though, try checking the float on your pump to see if it's seized. If not, trace the signal wire back to the dash, there could be a break somewhereAi theres fuel in it.Its moves a couple of mm every so often, maybe float is stuck Quote
