had a look on here but could only find how to swap the dampers an springs.
was wonderin how to change the standard springs to lowered ones?
the guide on here tells me how to get the whole unit off, i then clamp the springs but how do i get them off?
any help will be appreciated thanks. mayb pics aswell?
cheers string
Spring compressors. Compress the spring while its still on the shock, once compressed enough, remove the top mount, compress the new spring, put it on and work backwards. Easy job tbh mate! Can be a bitch to take the top mount off if you don't have the right tools!
