OK so i have the gt EP82 but there is a fue things that i need to no?
* will i need an EP91 ecu or will it work with the ep82 one??
* what is the difference in the look and what is it that needs to be added?/ is it more easy to just switch the whole looms over?
all info and help appreciated!
is this to go into your sr?
if so, and you have the ep82 loom?, i would use an ep82 ecu...
regarding the loom fitting straight in it doesnt, there are a few things not totally sure what, but the block connectors on the indicator storks dont match up i believe...
i have the whole ep82
