Budnbass Posted September 19, 2014 Posted September 19, 2014 Started cleaning up my rocker cover with a dye grinder and abrasive pad the other day but it's not getting in all the grooves anybody got and good tips for getting the corrosion off and getting it back to polished metal? Quote
AdamB Posted September 19, 2014 Posted September 19, 2014 I've used a dremel before and had no problems? A dremel with like a polishing bit with some auto sol or any metal polishing compound will bring it up. Quote
Budnbass Posted September 19, 2014 Author Posted September 19, 2014 Ok kool I'll have to raid my mates tool box tomorrow to try his dremel, cheers for that! Quote
AdamB Posted September 19, 2014 Posted September 19, 2014 You shouldn't have a problem with a dye grinder as they rotate faster than a dremel, guess your using the wrong bit. Quote
Budnbass Posted September 19, 2014 Author Posted September 19, 2014 Yeah I was using a corse abrasive pad on the dye grinder and a wire wheel on my drill, was just taking a while, I think I'm going to try the wire wheel on our bench grinder tomorrow that'll clean it up quicker I think. Quote
matty gt Posted September 19, 2014 Posted September 19, 2014 here is mine mate 5 minutes with an angle grinder with a wire brush wheel then some auto sol polish Quote
Budnbass Posted September 19, 2014 Author Posted September 19, 2014 Looks nice mate, that's exactly how I want mine too look! Hopefully then wire wheel on my bench grinder will bring it up to something like that, I'll upload the progress tomorrow Quote
