Just bought me a glanza front and some fogs fitting this to my n/a how do the wire up? Ill be using a switch instead of running off side lights
Thanks
The switch you use should power a relay, relay giving fused power to the fogs.
I believe in UK you need to need to have the fogs to turn on only if the park lights are on too.
I'd do it this way:
Park lights + ------------->pin 85 (relay) pin 86------->switch----->earth
Battery + ------>fuse---->pin 30 (relay) pin 87------->fogs------->earth
Anyone have a diagram i know one wire has to go to one of the pons on the bulbs but does the second pin have anything coming off?
