Jynx Posted September 28, 2014 Share Posted September 28, 2014 Just bought me a glanza front and some fogs fitting this to my n/a how do the wire up? Ill be using a switch instead of running off side lights Thanks Quote Link to post Share on other sites
FMuscle Posted September 29, 2014 Share Posted September 29, 2014 The switch you use should power a relay, relay giving fused power to the fogs.I believe in UK you need to need to have the fogs to turn on only if the park lights are on too. I'd do it this way:Park lights + ------------->pin 85 (relay) pin 86------->switch----->earthBattery + ------>fuse---->pin 30 (relay) pin 87------->fogs------->earth Quote Link to post Share on other sites
Jynx Posted September 29, 2014 Author Share Posted September 29, 2014 Thanks Do they earth to the relay or to the body? Quote Link to post Share on other sites
Jynx Posted September 29, 2014 Author Share Posted September 29, 2014 Anyone have a diagram i know one wire has to go to one of the pons on the bulbs but does the second pin have anything coming off? Quote Link to post Share on other sites
FMuscle Posted September 29, 2014 Share Posted September 29, 2014 Do they earth to the relay or to the body? To the body. Quote Link to post Share on other sites
