I've just done a compression test I didn't open throttle body I just turned it over I reading were 98,138,150,90 I know there shouldn't be more than a 15psi drop between each cylinder & that it should be around 170marl considering how old these engine are. Should I re do it with throttle body open??
Should all four plugs be out at one aswell?
I do one plug at a time but makes no real difference.
You should do it with the throttle wide open, but all it does is reduce the cylinder pressures. Don't know how you managed to get 150 with the throttle closed because thats about the average of a well worn engine. I believe they are normally around 80-90 with the throttle closed.
Edited by AdamB
i do mine with al plugs out an tb open 150 is a worn engine in my eyes BUT !!!!!!!! i got roasted for saying that on toc-irl and told him rebuild was on the cards soooon AND hoy no way they said gooood engine !!!!
so i hope i dont get roasted on here now to ha ha
not in 5e colins eyes anyways rebuild on the cards soon enough
cylinder 1 and 4 look like there is no rings left on them pistons / or dodgy valve seals on there but 99% sure its rings
Edited by 5e colin
Second that mate, 140 or lower is rebuild time from what I've read in the manual. Think of all that torque you'll be losing, it will just be escaping into the crankcase lol.
