Has anyone had a smokey white problem before remap, I figure I'm running rich due to upgrade turbo with everything else and it only ever occurs sometimes when I'm around 55/60 if I dip the clutch and rev it goes away straight away fitted a new pcv valve new oil/filter everything runs sweet no smoke at a standstill no constant smoke it's getting mapped either way very soon
All in all the fuel timing is going to be way out oil temperature is fine soon as the smoke stops it doesn't happen until I drive to 70 then slow or sometimes not even at all pull to junctions no problem, turbo was checked and fully rebuilt was all primed properly new plugs and leads no mayo on cap, I am running fresh blue coolant but compression came back fine, water test fine absolute mystery I'm hoping the map will sort it out :)
I have similair issue mate , random bits of smoke on downrevs or idle. have no idea why or how its getting there
It can be anything, chasing parts abit, could be 02 sensor, anything all I know is it's a bastard annoyance lol all I know is all these upgraded parts are not suitable for the stock ecu all down to mapping now
