Make: Toyota
Model: Starlet Glanza V (Sunroof)
Year: 1996 P Reg
Colour: 040 white
Mileage: 207,084 ( Might Increase slighly ) (Mixture of Kms and Miles)
MOT Due: 08th August 2015
TAX Expires: DUE TO NEW LAWS, LEGALLY CARS CANNOT BE SOLD WITH TAX ANYMORE
Cambelt + water pump changed at 206,478 (30/07/2014)
V5: Present
No. Previous Owners: 3
Reason For Sale: I have lost interest and also I don't have time to fix her.
Ownership: Just under 2 years
Condition: Used, Fair Condition, not mint, drivable but HAS problems.
Price: £1600
Location: CM23, bishops stortford, Hertfordshire, close to harlow essex or close to stansted airport
Theres a stack of receipts for the car but no import documents.
Unsure on how many km's it had done before it was changed to mph, so the reading is 207,084.
Since owning the car i have plunged money on it like mad, trying to rectify most problems. In my ownership the car has not done more than 5000miles, as it has been my weekend/project car.
She's had the cylinder head replaced due to smoke after been driven and coasted. ( IE, Stopped at a set traffic lights, it would most likely smoke). It made me believe stem seals had it. The cylinder head was brought from a member on ukso. He had the head skimmed, valves cleaned, valves re-seated, new stem seals and chemically cleaned.
In that process, head gasket, cambelt kit, water pump, inlet gasket, oil filter, oil, cam seal, exhaust gasket and rocker cover seal were changed. The injectors, fuel rail, inlet mani, cams, shims, cam pulley were cleaned in unleaded fuel. Rocker cover has also been sanded down and sprayed with high temperature paint.
* All the work was carried out by myself or a friend (mechanic) *
Spec:
* 4E-FTE engine, ct9 turbo
*Non-Lsd gearbox
*BLITZ Ecu
*BLITZ Front Mount Intercooler with Bov (Unsure if its a BLITZ bov or a replica)
*HKS adjustable Actuator
*Magnecore HT leads
*Ramhorn Style manifold and Decat (Unsure on make)
*KYB shocks, Tein springs. ( 57mm front drop, 50mm drop at back)
*Blitz Nur spec backbox
*16" team dynamics alloy wheels
*Liversport spoiler rep
*98Spec front bumper with 96spec fog lights
*Evo 4/5 Seats and door cards in dark purple velour.
*Spoiler for Sunroof
*D1 Spec lightweight wheel nuts.
*Catch can
*HKS Earthing Kit.
*Boost gauge
*Turbo timer
*Kenwood cd/ipod player plus 6x9s
*Climate Control. A/C removed.
*Jdm Flare
*Celica st202 steering wheel
*Stripped back
The sale will also include:
* Unpainted Rear Lip, 2X cat, 1X Manifold, 1X Ct9 Turbo in bits, 1X Ashtray/Cupholders, 1X Standard Ecu, 1X ZISCO oil stem seals, 1X double 52mm pillar pod, 1X drivers door handle, 1X drivers window motor/regulator, 1X rear wiper motor, 1X drivers door loom.
Bad bits:
*She still smokes a white oily smell on the tick over. It only happens after the car has been driven on boost, no smoke during boost, smokes while shes coasted. Also this smoke doesnt always happen. New Head fitted and still smokes. The turbo has no/minimal play in the shaft. Im going to assume the worse and say piston ring failure. This is only a guess as i have not done compression tests or leak tests.
*The buckets/shimms will need adjusting as its tapping lowder than average. Maybe could be the link below.
http://www.ukstarletowners.com/topic/85657-noisey-top-end-reshimming-needed/
*It has a small oil leak but i cannot find where its leaking from.
*Gearbox does not like quick gear changes as it grinds now and then.
*Front drivers wheel bearing needs changing as makes a little bit of noise and stated in mot paper
*Rear drivers wheel arch has started to show a tiny bit of rust
*Steering column had some play. Moved up and down. Ive tighten it at lowest point the steering could go. It can be re-adjusted, I just dont know how to fix it properly.
*Front Bumper has seen better days. Could do with a refurb. (Picture)
*Drivers door has been keyed. (Picture)
*Front Passenger wheel arch plastic needs fitting in
*Could be other little things i just cannot rebember but major problems are listed above.
*** The car still runs ok, drives from A to B ***
*** I am not interested in part exchanges or swaps, just a quick sale ***
*** Views Welcome ***
***Any questions PM here or my mobile 07787446383. I Might not answer due to work but just leave a message ***
Pictures
That's a Bargain would have nabbed it if it was closer
Only selling the blitz ecu would mean you would have a glanza for 1100!
Selling the car as a whole
