Glanzacoley Posted October 14, 2014 Author Posted October 14, 2014 Same shafts, flywheel & clutch mate? What would I need to do for shifter inside then? Quote
5e colin Posted October 14, 2014 Posted October 14, 2014 your current shafts will slide in the g6 box mate and you keep your turbo or na clutch that you already have you could do with the cables because the bracket on box is a bit diferent otherwise it need a bit of messing to get that right Quote
