Ep911-20v Posted October 20, 2014 Share Posted October 20, 2014 Has anyone tried rails for brides/recaros from anything mass produced like Civic Wrx Silvia I'm sure they still need modifying but minimal modification to the rails is what I'm looking for Any ideas of close fitments??? Quote Link to post Share on other sites
JamesP Posted October 20, 2014 Share Posted October 20, 2014 The closest I found when fitting my seats were integra dc2 rails. The two front feet just needing bending slightly and the holes making slightly wider. Its the back ones that are a bit harder. I made a bracket for the back one that bolts to the exhaust tunnel on the starlet. Cut and reweld the other rear foot a bit closer in and out to a slight angle. If you haven't got a welder maybe it could be bolted back on but I'm not sure. Unfortunately I don't think there's any rails that won't need a fair bit of modding. Quote Link to post Share on other sites
Ep911-20v Posted October 20, 2014 Author Share Posted October 20, 2014 I thought so welding feet on seems to be what needs to be done for all the other post was just interested if one was close enough Even if a hole was drilled through the floor and a new thread cut or even a heli-coil was used that's what I'm thinking is possible My thread repair guy from work does all sorts of fabrication and has told me heli coils are used alot in motor sport due to having three threads holding instead of 1 (if it's carried out right anyway) Quote Link to post Share on other sites
Charlie28 Posted October 22, 2014 Share Posted October 22, 2014 I modified DC2 rails when i made my frames. Cut the feet off your standard glanza seat frames and weld to your other rail. Takes abit of time and alot of grinding! Quote Link to post Share on other sites
