Jim* Posted November 2, 2014 Posted November 2, 2014 Ep91, has gone really tight into first and second but reverse is fine? Anybody got any ideas what this could be? Quote
5e colin Posted November 2, 2014 Posted November 2, 2014 cable or the sugar cube on the selector on the box ? Quote
Jim* Posted November 2, 2014 Author Posted November 2, 2014 Where is the sugar cube located? How would I check if it's the cable? cable or the sugar cube on the selector on the box ? Quote
5e colin Posted November 2, 2014 Posted November 2, 2014 undo the cable on the box and iside on the lever then pul push the cable it should go fairly easy the cube is on the the bracket on the box the rear cable atatches to it and is bolted to the box on the far right undo the 2 bolts and rotate the cube 90degree and refit Quote
