i have a TB28 turbo and i was told that i had to put some upgrade injectors. but what should i do then ?
and what is the max boost pressure on a originale motor and what can it handle ?
//Mathias
I'm not 100% but I think that the tb28 is a similar size to the td04 I recon you would be ok running 1 bar on the jam and standard injectors but don't hold me to it lol. Your best would be find a tuner near you that works with greddy emanage ecu's and he should be able to tell you what setup to run for what boost pressure etc. hope this helps dude
cant use bigger on a plug and play only on the pfc fcon !!!!
you can fit bigger 1s but you also will need a rrfpr you tune her for on boost as good as you can with the rrfpr but she will be a disaster on idle and low down revs under boost
i did this to mmy mines with tdo5 and 370cc injectors and never again no mpg attal
i don't get what you are saying my english is only medium good :)
i don't know what rrfpr is ??
can you maybe do it in a kinder state of mind ;)
And what are your's opinion on a mega squirt ?
We don't have any tuner people here in Denmark that does any Glanza's we only have around 5-10 Glanza's in Denmark, so not any people know the car, so that's why we are trying here :)
//Mathias :)
ha ha shit my tongue is not english to im a continental boy :) :)
rrfpr = rising rate feul presure regulater
megasquirt if you can get it to work then go for that , it has soo many options to tune things and self tune but flipping hard to set up i have 1 but still neads soldering etc etc and lots more research needed before i ever go there
if there are no tuners then get a pfc fcon with bigger injectors that can be self tuned to a degree with a wideband afr gauge
okay thanks :)
pfc fcon is that a piggy back you mean ?
And does anyone wanna help me with explaining and finding things, i want to get around 200-250 bhp :)
i've put a picture on so you can see what I've have
//Mathias :)
looks good matias :) t series turbo ??? if you only go around 200to 250 get a pfc fcon !!! i run it to :) its sub computer but only 1 that will take bigger injectors as plug and play
this is only pic i have of my pfc fcon can be found cheap both ep82 and 91 can be used on both with a bit of wiring and jumper loom !!!!!
and 370c injectors like these
is enough to run what you want before you need to forge the engine !!!
both are for sale on here phill is selling the injectors for 90£ i will dig up link later
and also a pfc fcon is for sale on ere for 180£ with gcc if thats sold i can get fpc with no GCC in ireland for you i think if its not sold by now ??
it can be yes its set up for for stock ecus but can be set up with a p%p to to take advantage of speed cut feul cut and 8000rpm limiter
i drove around for 2 months with both mated together and al seemed fine
Edited by 5e colin
example a hks pfc fcon and a plug in mines ecu works :) :)
depends if you want to rev higher then your current limiter ???? stock ecu and pfc to start with is great then if you go bigger you could buy a plug in ecu like mines toms etc etc for the higher rpm limit
if you only do stock limiter then no plug in ecu is needed just pfc :)
