Shwdii Beii Posted November 5, 2014 Posted November 5, 2014 Hey, going to be reshimming my 4e in the next couple days as it's very tappy top end, had the inlet cam out and retensioned that which no effect ): so left to believe it must be the valve clearnaces! Engine has done about 2000 since rebuild.Just wondering what should the valve clearnaces be? Is there any info/guides on this?Any info will be great!Thanks Quote
5e colin Posted November 7, 2014 Posted November 7, 2014 there is difeent specs for that i have seen 20/30 and 15/25 ???? i thin it was have a look in a service manual you can take them as your guide Quote
Moose Posted November 15, 2014 Posted November 15, 2014 For stock camshafts4E-FTE Valve clearance with the engine cold are:Intake 0.17mm - 0.23mmExhaust 0.27mm - 0.33mmI got this from a manualhttp://www.toyotagtturbo.com/forums/showthread.php?99425-4efte-engine-timing-and-torkIt's at the bottom of the pageHope this helps Quote
