Phil Posted January 5, 2015 Author Posted January 5, 2015 Bump, no one going for big power? Phil Quote
Phil Posted January 16, 2015 Author Posted January 16, 2015 Bummmmmmp......(wait for it)....... tish Phil Quote
Phil Posted February 4, 2015 Author Posted February 4, 2015 BUMP nobody building a fancy head these days? Phil Quote
Phil Posted February 23, 2015 Author Posted February 23, 2015 Somebody buy me. perfect to run with lairy cams/yaris solid buckets etc. Phil Quote
Phil Posted March 23, 2015 Author Posted March 23, 2015 Is NOBODY doing fancy pants head builds these days Bump Phil Quote
Phil Posted April 2, 2015 Author Posted April 2, 2015 bump checked these springs against genuine cruise ones and they are the same length and the cruise ones are thicker coil than stock aswell so i doubt very much that the 4age will coil bind or give issues. BIG Bump Phil Quote
Phil Posted April 9, 2015 Author Posted April 9, 2015 bump checked these springs against genuine cruise ones and they are the same length and the cruise ones are thicker coil than stock aswell so i doubt very much that the 4age will coil bind or give issues. BIG Bump Phil What he said. Phil Quote
AdamB Posted April 11, 2015 Posted April 11, 2015 Can't believe these still here Phil. Just to add the valve guides will fit a 4E head, both the 4E and 4AGE use a 6mm stem and the clearance is the same between both engines. I've cross referenced between the 4AGE engine manual and the 4E manual. I've got a full set of 16 of the Yaris solid lifers sat here, I'll do a deal with if someone buys the springs and guides from Phil Quote
Danza Posted June 2, 2022 Posted June 2, 2022 (edited) Valve Guides Still available? Edited June 2, 2022 by Danza Quote
