  • 2 weeks later...
  • 4 weeks later...
  • 2 weeks later...
bump
checked these springs against genuine cruise ones and they are the same length
and the cruise ones are thicker coil than stock aswell so i doubt very much that the 4age will coil bind or give issues.
BIG Bump
Phil
bump
BIG Bump
Phil
What he said.
Phil
Can't believe these still here Phil.
Just to add the valve guides will fit a 4E head, both the 4E and 4AGE use a 6mm stem and the clearance is the same between both engines. I've cross referenced between the 4AGE engine manual and the 4E manual.
I've got a full set of 16 of the Yaris solid lifers sat here, I'll do a deal with if someone buys the springs and guides from Phil :thumbsup:
  • 7 years later...
