Alright,
I've just put a new clutch in my glanza and im needing to no what kind of oil i need and how much the glanza box holds.
I also have a LSD, if any one can help cheers.
Hi mate
Check the section you just posted in (MOT and Maintenance) as there is loads of info on gearbox oil, what to use, how much etc already covered ;)
Cheers
Joz
How am i ment to no what lsd i have..., what will happen if it the wrong oil.
What oil do you put in for a viscous diff and will it be ok putting that oil in if its not a viscous diff.
