BenV Posted January 14, 2008 Posted January 14, 2008 does any body have a fuse box diagram for a glanza or N/A. im guessing they mite be the same. Quote
Sparky Posted January 14, 2008 Posted January 14, 2008 Should tell you what fuses are what on the inside of the fox box cover mate Quote
BenV Posted January 14, 2008 Author Posted January 14, 2008 Should tell you what fuses are what on the inside of the fox box cover mateteh one undre the wheel hasnt got any writing.and my clocks back light has gone so i need to find out which fuse ut is? Quote
Sparky Posted January 14, 2008 Posted January 14, 2008 Strange in the n/a it says it on the back of the plastic you take out Quote
BenV Posted January 14, 2008 Author Posted January 14, 2008 the 1 under the steering wheel is like a mini fuse box with tiny fuses in it. Quote
Glanza_Ragger Posted January 18, 2008 Posted January 18, 2008 just chek them allYou should have a little white sticker on the inside of the flap that you pull down, maybe it fell off ?I dont have time to take a pic of mine atm, but maybe someone else can for him?? Quote
