Si@Fiske Posted January 14, 2008 Posted January 14, 2008 just changed over to some ngk iridium 7 plugs and it keeps missfiring.... why?! cheers guysSi Quote
Rich Posted January 14, 2008 Posted January 14, 2008 Leads connected properly (to plug and dizzy cap)? Moisture in the leads around the plug? correct plugs? Plugs in propperly? could be one of a few things really.If you have checked all that and it still does it, I'd suggest putting the old ones back in and check see if they do it aswell. Quote
Tintin_SR Posted January 15, 2008 Posted January 15, 2008 make shoe all the HT lead and plugs are ALL pushed down proper, if not did you check the spark plug gaps be for putting them in? Quote
oli_h Posted January 15, 2008 Posted January 15, 2008 stop caining the fuck out of it may solve the issue ;) Quote
Sparky Posted January 15, 2008 Posted January 15, 2008 stop caining the fuck out of it may solve the issue ;)Any chance you could reply to my PM Oli Quote
StarletRick Posted January 15, 2008 Posted January 15, 2008 i believe tintin has hit the prize with this. if they aint gapped right they will blow out and youll get some ube missfires.common problem with new plugs Quote
oli_h Posted January 15, 2008 Posted January 15, 2008 Any chance you could reply to my PM Oli just did mate Quote
Si@Fiske Posted January 15, 2008 Author Posted January 15, 2008 cheers guys,well ive kinda concluded i think its fuel cut, it only does it for a blip at 5k and it is boosting alot!also it doesnt do it in low boost = thinking its fuel cut..cheerssi Quote
