TRD-1 Posted December 8, 2014 Posted December 8, 2014 Hi Guys, I need some parts for a conversion, if anyone has any of the following give me a shout please, doesn't matter if there from a EP82 or EP91 but must be from the 4EFTE. 1. Cat support bracket (the one that bolts to the cat and the block) 2. Wiring plugs, if anyone has a damaged engine wiring loom I need the following plugs: Distributor, Ignitor, Coil, Idle control valve, TPS sensor 3. Stock fuel pressure regulator Thanks
