Can you use a HKS EBC to increase the boost to 1 bar using the tandard actuator? If not, then why would you use a EBC on a adjustable actuator when you can just adjust it manually?
You could, a lad I know uses blitz ebc on stock actuator on his gt4 but they say the springs go weak in the stock one's so they use adjustable HKS one's as the spring is stiffer they tend to set them to 0.7 0.8 and let the ebc do the rest they are more useful to an external wastegate set up the main reason for an ebc is for when you boost hits full pressure as the revs go higher boost tends to drop off the ebc keeps that pressure up through the high rev
