Andy32 Posted January 12, 2015 Share Posted January 12, 2015 just wondered if there were any tried and tested track suspension setups out there?use the car as a daily but also plan on doing at least half a dozen track sessions during the year.just fitted a set of D2 coilovers so can adjust camber on front so could do with some geometry figures to try out!!thanks again for any info. Quote Link to post Share on other sites
mikey4410 Posted January 13, 2015 Share Posted January 13, 2015 (edited) had my car 3d aligned including the rear camber I fabricated. I run 2° front camber and 2° rear camber. I forgot the front toe but can find out and let u know.my car handles extremely well as I managed to corner weight it after the alignment. I added 20kgs of weight in rear also and ended up with 55/45 rear distribution with half a tank of fuel.rear anti roll bar also makes a nice difference.the rear of the car sits very slightly lower than front also. Edited January 13, 2015 by mikey4410 Quote Link to post Share on other sites
Andy32 Posted January 13, 2015 Author Share Posted January 13, 2015 so how much of a job is the arb too fit?? Quote Link to post Share on other sites
mikey4410 Posted January 13, 2015 Share Posted January 13, 2015 really not hard...I didnt even have to remove rear bumper. Quote Link to post Share on other sites
Andy32 Posted January 13, 2015 Author Share Posted January 13, 2015 do you know if there is a thread on it?does it use existing fitting points or do you have to make them? Quote Link to post Share on other sites
mikey4410 Posted January 13, 2015 Share Posted January 13, 2015 you have to drill out to holes in top of chassis at back.realy easy to do. they have to line up parallel with the chassis when cars on floor.u cant go wrong Quote Link to post Share on other sites
