curtis1932 Posted January 13, 2015 Posted January 13, 2015 Does any 1 have or know the wiring diagram for the key barral i need to kbow thees. ACC output (+) 30A(max)starter output(+) 25A (max) +12vign1 output(+) 30A(max)Ign2output (+) 30A (max)groundThanks Quote
turbo Grant Posted January 13, 2015 Posted January 13, 2015 Should be on the back of the ignition switch. They have the markings moulded into the plastic next to the pins. So unless you don't have the barrel you should have it there Quote
