Rich-k Posted January 24, 2015 Posted January 24, 2015 Need some help please!!! Plugged SR dials into my sportif, all the lights work and plugs clipped in properly, but my temp gauge, rev counter and fuel gauge dont work!!!! Any ideas please!!! Thanks! Quote
vizzioarts Posted January 24, 2015 Posted January 24, 2015 They need a bit of rewiring. I made this when i did mine. Have a look, hope it helps.http://www.ukstarletowners.com/topic/65688-clock-conversion-starlet-na-to-starlet-sr-cluster/#entry841019 Quote
Rich-k Posted January 24, 2015 Author Posted January 24, 2015 Thank you so much!! Ill try it now thank you! Quote
Rich-k Posted January 24, 2015 Author Posted January 24, 2015 Just looked and my wires are totally different to yours! Quote
vizzioarts Posted January 25, 2015 Posted January 25, 2015 Just looked and my wires are totally different to yours! In that case. Look at the circuit on the back of the clocks. trace each pin to where they send power to the components on your clocks. Then do the same for the pins on the new sr clocks. Work out your differences and find which wires need to be swapped.Hope that makes sense. In my case the signal for the rev gauge was already in the correct module.if you cant find it, i can only assume all the ecu does is send a variable voltage to that pin, so use a multimeter on every pin and find which one changes voltage with revs.It puzzles me how many different variations of loom was made for these starlets, doesn't make much sense as to why haha. Quote
