My engine management light comes on if I cruise at a steady speed in top gear for a prelonged period of time, probably around the 60mph mark, if I turn it off and on it goes away again, if I'm just going around town it's fine, if I thrash around its fine.
just when cruising, anybody heard of or had anything like this before?
Yes mate.
I had speed signal failure only happens
If ecu doesn't read signal above certain rpms for a period of time.
Also do a diagnostic check and see what fault code flashes up
Edited by jayc-glanza17
