Ollieh17 Posted January 25, 2015 Posted January 25, 2015 Anyone know what size they are? Got some replacement ball joints from ID workz and the old bolts dont fit? Quote
Mad Mike EP82 Posted January 25, 2015 Posted January 25, 2015 Bolts should fit wrong ball joint. Quote
Ollieh17 Posted January 25, 2015 Author Posted January 25, 2015 They are super tight and look like they are cross threading Quote
Mad Mike EP82 Posted January 26, 2015 Posted January 26, 2015 If it's not lined up it will be tight use a bar to leaver the wishbone in to place Quote
Ollieh17 Posted January 26, 2015 Author Posted January 26, 2015 As in one the balljoints in my hand. I cant screw a nut on the two threaded studs. Ordering up the bolts from toyota Quote
Mad Mike EP82 Posted January 26, 2015 Posted January 26, 2015 As in one the balljoints in my hand. I cant screw a nut on the two threaded studs. Ordering up the bolts from toyotaIf your bolts are ok send ball joint back if it's faulty Quote
tango123 Posted January 27, 2015 Posted January 27, 2015 new bolt an nuts should have come with the ball joint Quote
