lukeyy_EP91 Posted February 6, 2015 Share Posted February 6, 2015 What's else can I do to my na engine to make it quickerAlready got corolla inlet, exhaust & apexi filter Quote Link to post Share on other sites
morgey Posted February 6, 2015 Share Posted February 6, 2015 Moved to the correct section. Also this has been covered numberous times, have a quick try on the search function you should get a few results Quote Link to post Share on other sites
lukeyy_EP91 Posted February 6, 2015 Author Share Posted February 6, 2015 Thanks Quote Link to post Share on other sites
onnaj1000 Posted February 7, 2015 Share Posted February 7, 2015 Think that with the filter you loose power due to sucking in warm air Quote Link to post Share on other sites
lukeyy_EP91 Posted February 8, 2015 Author Share Posted February 8, 2015 Yeah I was told about that actually , was just going to put standard one back on with a k&n filter Quote Link to post Share on other sites
onnaj1000 Posted February 8, 2015 Share Posted February 8, 2015 What exhaust manifold did you use?Do you notice a lot of difference with the corolla intake? Quote Link to post Share on other sites
lukeyy_EP91 Posted February 15, 2015 Author Share Posted February 15, 2015 Corolla. Yes more torque. Worth the buy Quote Link to post Share on other sites
onnaj1000 Posted February 15, 2015 Share Posted February 15, 2015 Will that corolla (e10 exhaust mani I guess) fit right away or should it be welded on the exhaust? Quote Link to post Share on other sites
onnaj1000 Posted February 26, 2016 Share Posted February 26, 2016 Can someone confirm if the e10 exhaust manifold is a direct fit? Quote Link to post Share on other sites
