Right, going to buy some of these soon, how have you guys fitted yours, or how would the best way be to fit some..
Im thinking, either buy a sheet of carbon and cut some triangular plates out, bond them to the door panel
OR
Forget the carbon and bolt them directly to the door panel?
Does anybody have any pictures of the door with the oem mirrors removed ? so i can get an idea of the holes that are left underneath the mirror that id need to weld and fill.
Muchos thanks :)
Muddyell just go a mody shop to fit those mirrors :)
Hey cut the mount off the standard Starlet base and got the mirror mounted in the right place and just filled over it...check his thread they look tidy
;) Well done bro, thats a sorted idea.Out comes the filler :p
Apparently the bit at the bottom of base plate is really hard to cut off mate just do that you know before you try
:) Thanks for the heads up dude,But im sure ill scare it off once ive introduced it to Mr Angle Grinder :)
Thanks though bud, ill let you know how i get on
