Starlet__SR Posted February 24, 2015 Posted February 24, 2015 (edited) Year:1995Model: Toyota Cynos AlphaTax:N/AMOT: 05/11/2015Mileage: 72.5k miles clocks showing 81264 mix of kms/miles.Description: Purchased this a couple of months ago but due to doing a few motorway miles i'm looking to move onto something more comfortable/sensible. The car itself is a lovely little drive. It starts and stops as it should. This example in question is fitted with the 5EFE, paired with the 4 speed automatic. The engine itself is sweet as a nut and pulls strong. The car itself drives straight and true. No accident damage to speak of. Apart from a few blemishes (small stonechips, one small parking dent) on the bodywork its rather clean for a 20 year old car. The underside is spotless with no rust to speak of, including the wheel arches and sills. Prior to me purchasing the car the previous owner fitted a brand new set of wheels and tyres (Fox Racing/Blacklion Tyres) for which I have the invoice for. The car itself has little things like OE Cupholders fitted, a longlife stainless catback exhaust (not too loud).Since I took ownership i've done a few little things to bring the car upto scratch, these include:-New Brembo front discs with EBC Yellowstuff padsFull engine service using genuine oil filter/oil, NGK Platinum plugs, gearbox oil flush and refill, new air filter.Strip front and rear brakes, clean and regreaseSony Xplod Double Din Head unitOsram Nightbreakers with Osram LED sidelights. If there's anything i've missed by all means drop me a message or post. The engine itself is asking for a turbo. I've also started collecting parts for a manual conversion which can be negotiated, this includes a new 3ETE Flywheel so a 212mm clutch can be used, clutch master/slave cylinders and ARP Flywheel bolts.Price:£500 on steel wheelsPictures:Contact Details: PM or 07951 861170 Edited March 3, 2015 by Starlet__SR Quote
Starlet__SR Posted February 28, 2015 Author Posted February 28, 2015 Bump! Any interest in breaking the car? What does a good 5EFE command?Day Quote
Starlet__SR Posted March 3, 2015 Author Posted March 3, 2015 BUMP!!!! £500 as the car stands minus the alloys, will come with steel wheels!!!Day Quote
Starlet__SR Posted March 4, 2015 Author Posted March 4, 2015 We're are you and the car located mate?Worksop, not far from sheffield. Can pick you up from the nearest train station if thats any help.ThanksDay Quote
