Efi fuse keeps blowing in engine bay only meaning no spark, checked plugs dizzy king lead etc all earths are spot on getting fuel, is it my igniter :s!? Cus that was also fully working before I chhanged engines
Use a process of elimination - unplug the ecu/ignitor/coil/injectors/idle up solinoids/high-low boost solinoid then try each one at a time to see which one is causing the issue. Also try another main efi relay in the engine bay fuse box as this is what actually supplied the power.
