Oil filter relocator,decat,4efte cat back unless your going to weld a flange onto your own exhaust,Intercooler,boost gauge, map sensor,ecu knock sensor? Few other bits aswell as someone else can confirm, better off getting a 4efte and dropping it in tbh, less hassle and more reliable in the end
I've got a td04 with manifold actuator and down pipe also have a set of denso 370cc injectors if your interested
