Make about the same in stock form, get slight more lag from the k24,but you'll be hard pressed to find a k24 for cheap these days, where as the td04 are on every man and his dogs cars
i would of said you get more lag from a td04!! Or is it because it's a 13g? im running sard k24 depending on the gear you're in it will start spooling around 2.5-3000rpm and hits full boost at 3500rpm @1.4bar!
